    mbot3D GRID II Announced - 1,245
    mbot3D just announced their new 3D Printer. It seems like it is only available in Europe for now though.
    The GRID II is a third generation printer from mbot3D. This sturdy metal frame 3d printer has one of the biggest build sizes on the market for desktop 3D Printers, 260x230x200mm. It is available in single head or dual head configuration.
    The new printer features an automatic build plate calibration system that guides the user through the setup and then at every print probes the surface and uses the calibrated distance. The printer also features a glass build plate , and a magnetic build plate holder making it a breeze to remove your build plate to remove your prints, which ensures your build plate calibration is kept in top condition.
    The mbot3D GRID II also feature single or dual print fans to make sure your PLA prints are perfect every time!
    The printer is bundled with a SD card, and an exclusive tool box with the basic tools need for maintenance of the printer.
    http://mbot3d.eu/product/mbot3d-grid2/
    SPECIFICATIONS
    PHYSICAL DIMENSIONS
    Size 405 mm x 405 mm x 410 mm
    Shipping Box 520 mm x 520 mm x 520 mm
    Weight 18 Kg
    ELECTRICAL
    AC Input 100-240V, 50-60 Hz
    Power Requirements 24V DC @ 6.25 amps
    Connectivity USB, SD card with SDHC support
    MECHANICAL
    Chassis Steel
    Front Cover PVC Panel
    XYZ Bearings IKO Linear Bearings
    Stepper Motors 1.8 step angle with 1/16 micro stepping
    SOFTWARE
    Firmware Sailfish OS Firmware
    Printer Host Software ReplicatorG
    File Types STL
    Operating Systems Windows(XP/7/8/8.1), Ubuntu Linux(10.04+), Mac OS X (10.6+)
    Engineer-in-Training
    Jun 2014
    The magnetic plate seems neat. The Z rods do seem thin though.
    I guess if not avail in U.S. then it does not matter for me though.
