Page 4 of 4 FirstFirst ... 234
Results 31 to 39 of 39
Thread: Wax Filament
  1. #31
    Technician
    Jan 2015
    Location
    Traverse City MI
    Add Wes@MachWax on Facebook
    Since PVA is slightly cheaper, and water soluble, I feel it would be a better alternative than wax filament for support structures. That's assuming wax would even work for that purpose. But, it was never really intended for that purpose either.
    We have been working on 3mm, but as of now we are not happy with our results. We are waiting for some parts to arrive that we hope will improve things. The material is much more difficult to extrude than ABS, so we are still experimenting, and learning.
    We will be adding a 1kg option in the 1.75. This will be a lower cost/gram than the 1 lb. spools.
    Even though the raw materials are more than the Chinese pellets most filament producers run, the increased cost (compared to plastics) is mostly attributed to the extra time, and difficulty required to get this material onto spools. It just is what it is. As of now there is only one comparable material for the purpose of casting, and ours is priced quite a bit lower.
  2. #32
    Technician
    Jan 2015
    Location
    Traverse City MI
    The person casting the YodaBuddha sent this teaser pic today. Not completely done, but I think it looks great so far.
    This pic was just after hosing off the investment (before any polishing).
  3. #33
    Technologist bford903's Avatar
    Sep 2014
    Location
    Albuquerque, NM
    Add bford903 on Facebook
    Very nice....it is. Want one I do. :-)
  4. #34
    wax filament a good design 3d print contribute to engineer industrial
    We together with Chinese Academy of Sciences supply a
    Wax filament ,only 3.0mm available
    some photo show :
    below one photo is not wax filament print made, it is metal. something that if you are a engineer doing iron mould will understand. make iron model with wax model inside then melt flow out, then make the iron one.
    we are , www.stronghero.cn
    if you want to order just contact: sales01@stronghero.cn
    $30/kg ,on roll,paypal available
    Last edited by 3ddplas; 04-03-2015 at 05:15 AM. Reason: better understand for all 3d printer fans
  5. #35
    How every one think? it worth for 3D print do a good job for engineer?
  6. #36
    Technician
    Jan 2015
    Location
    Traverse City MI
    Those look nice. But, would you mind making your own thread?
    And from your pictures, your filament looks very much like plastic. What are your printing temperatures?
  7. #37
    sorry sir, I don't look through all this thread, sorry for my rude come in.
    it is a real wax filament, not plastic, process temperature for extruder is only 100deg.
    I think call it PE-wax filament will be more accurate, it must can be melt to flow and can be extrude to be filament ,much like plastic, a low melt point plastic
  8. #38
    Technician
    Jan 2015
    Location
    Traverse City MI
    Quote Originally Posted by 3ddplas View Post
    My mistake then. It was the string pattern at the bottom of the solo Buddha that made me think that.
    Great job on the prints. What printer are you using? What resolution were the Buddhas printed at? The cast part came out well too.
  9. #39
    Great
    Awesome
