1 Attachment(s)
Nozzle size vs wall thickness
Hello,
I would like to ask more experienced users for explenation and help with this issue. I would like to print an element that has 1mm wide walls. I use HBOT printer with 0.4 nozzle. It doesn't matter which slicing software i use, each time it makes only one perimeter on each side of the wall leaving a hole between those, although in some walls (same thickness) it looks ok. I used diffrent infill settings (including 100%) getting the same result, i also used diffrent perimeters amount. The effect is that print has basically has no stiffnes and is easily broken. I tried to change extrusion width to 0.33 (and it sliced well) but the print itself wasn't any good as well. Below i post screenshot explaining what i mean. How can i overcome that problem?
Attachment 3919
Thanks in advance
