Simple Hollow Tubes
Im a simple soap maker who loves gadgets. Wife will not allow me to purchase my own 3DP but maybe i can use yours.
I have this idea to make some soap with some basic shapes in it. Soap is in liquid form and is poured in the end of the tube. Once dried i push it out with a similar shaped hard object and push it out the other end.
Think cookie cutter simple here. 1, 3 armed cactus and 1, coyote howling. I need a 15-17" hollow tube 1 1/2" tall with 1 end cap(if possible) each and 1 plunger shape for each, like a push block to shove inside to force the soap out small enough to slide inside. Please give me an idea of what it would cost.
http://cdn.shopify.com/s/files/1/003...g?v=1337697648
http://cdn.shopify.com/s/files/1/003...g?v=1337285867
what country do you live in ?
and when you say 1.5 inches tall - do you mean 1.5 inches internal diameter ?
And have you looked at the plumbing supplies section in your local hardware store ? plastic Tubes and end caps are a staple of the plumbing industry.
All you need to push the soap out is a length of wooden dowel the right diameter or slightly smaller with vinyl tape wrapping used to form the correct size end.
That would be a much easier, cheaper and quicker way of doing this :-)
Tape, tubing and a hacksaw and the jobs done :-)
1 Attachment(s)
I live in the USA. Southern California.
I don't want more round soap. I want shaped soap I can then use in my block soap.
I do use 3" pvc for round soap.
Yes I need it to push out a 1.5" soap. Need to be smooth
Attachment 6110
Ah - so you don't want tubes - you want very tall extruded shapes !
It really wasn't clear :-)
Yes please! I need to be able to pour my soap batter in and once it dries push it out. Can any one here help me make these?
Email me at cm3dsales@gmail.com. We are also in Southern California and can help you out.
Aaron
good - pretty straightforward prints. But you need someone local to cut down on costs :-)
