Monoprice Maker Select V2 - Missing Layers
Hi guys, got about 5 days of print time on my Monoprice and I'm totally in love. Dialed in acceleration and jerk pretty fast, printed the diicooler for more uniform cooling, and more or less know the likes/dislikes of my different PLAs depending on print.
But I've recently been struggling with missing layers. They will either appear very regularly at distinct intervals, or only at the tops of some geometry. Any idea what could be causing this? Didn't find any clogs, tried slowing the prints down to 40 from 60 mm/s and even upped my flow to 107%.
10mm3 Test printed at .2mm layer height, 210 degrees, 90% fan speed, 40 mm/s: http://imgur.com/a/K1EHu
Any input you have would be great, thanks!
EDIT: Solved! The issue was a small amount of old filament that had shaved itself off of the extruder and wound around the axle, causing cyclical issues in feeding.
