Hi all,
I had a 3D printing company print a 3mm thick ring with around 430mm o.d. using the Vero material. Over the past two weeks the ambient temperature in our lab changed quite a lot (down by over 10 deg C) and I found the ring to have shrunken by 2-3mm in terms of arc length. Is this something I should expect for Vero? Is there any material that has a lower shrinkage rate?
Thanks
