#20 - Minecraft Fence System
http://www.thingiverse.com/thing:268719
http://thingiverse-production.s3.ama...w_featured.jpg
#23 - Spring Loaded Pen Holder
http://www.thingiverse.com/thing:268679
Quote:
A spring loaded pen holder that mounts in aluminum extrusion. The spring makes up for uneven surfaces and the pen takes an easier ride.
Made specifically for paper mate flair pens.
#24 - Pokemon Monster Ball
http://www.thingiverse.com/thing:268674
#25 - Jeep Trail Rated 4X4 Emblem
http://www.thingiverse.com/thing:268659
#26 - Prusa i3 E3D V5 Hotend Mount/Fan
http://www.thingiverse.com/thing:268646
Quote:
I couldn't really find a bowden mount designed specifically for the Prusa i3 and E3D V5 hotend that also had fan mounts, so I made this one up. This is the 1st design iteration. Designed to use (3) 40mm fans.
Note you will have to drill holes to mount the twin nozzle cooling fans. I left the holes out to simplify printing.
#27 - 40 MM T-Slot Angle Bracket with Adjustable Foot
http://www.thingiverse.com/thing:268615
Quote:
This is an adjustable foot for 40 mm T-Slot aluminium extrusion combined with a 90 degree bracket. It was design, especially for a 3D printer. It can serve other purposes obviously.
You will likely need 4 feet and 4 angle brackets. Furthermore, you will need four threaded rods of either 8mm or 5/16" in diameter. They must be at least 50 mm length. Finally, to be able to assemble the feet, you will need to thread the brackets and the feet.
#28 - Original Coke Bottle Set
http://www.thingiverse.com/thing:223223
#29 - Laser and Clip Mods for Rubberband Gun
http://www.thingiverse.com/thing:268524
Quote:
A while back, Gavilan posted a design for a really awesome Rubber Band Gun but I thought it was lacking one or two things.
So I added a Laser Sight mount (which fits laser pens such as this: Green Laser Pointer )
And an Ammo Clip that can store additional rubber bands.
These mods can be easily added to Gavilan's original design. Add just one of them or both!
