Trying to solve a Z offset
When using ABL I have a Z offset that I haven't been able to sort and could use some advice. When I issue a G28 the X and Y both show 0 with an M114 after the homing command, but the Z shows 2.86. My offset for Z in the ABL is 1.80, so the print is starting way too high. I have tried a G92 to reset zero point for all axis, and then issue a M114 and all axis show 0, but if I home again (whether I use the home button, Z home button, or issue G28) the Z is at 2.86 again. When I reload the stock firmware without ABL, it works fine so it is something I have done to the ABL code. I'm just not finding it. And suggestions would be appreciated.
