A fix for COOLDOWN on the LCD
The PREPARE / COOLDOWN menu item does not work correctly on the version of Marlin designed for my 10" i3v. Instead of turning off both the hot end heater (gcode M104 S0) and the bed heater (M140 S0), it turns off only the hot end heater and leaves the bed heater running. The second half of the command is not interpreted correctly so COOLDOWN does not reset the bed target to 0C. Examining the code, it appears as though the attempt to send 2 gcode commands in the same text string does not work.
I have implemented a fix that works with the Marlin_RAMPS_EPCOS_i3v10 code that I downloaded from Makerfarm. I imagine it would work with other versions as well. The fix consists of adding a short function to replace the inline code that attempts to send 2 gcode commands at once. The added function sends the hot end and bed heater codes individually. It also causes a return to the main menu after selecting COOLDOWN (I prefer this behavior).
Two changes are required in the ultralcd.cpp file (only that file is affected). First, add a new lcd_cooldown() function at a convenient location in the code:
Code:
#ifdef SDSUPPORT
static void lcd_autostart_sd()
card.lastnr=0;
card.setroot();
card.checkautostart(true);
#endif
// ------------- begin added 11/12/14 code (makes cooldown function correctly)
void lcd_cooldown()
enquecommand_P(PSTR("M104 S0"));
enquecommand_P(PSTR("M140 S0"));
lcd_return_to_status();
// ----------------------- end 11/12/14 added code
void lcd_preheat_pla()
setTargetHotend0(plaPreheatHotendTemp);
setTargetHotend1(plaPreheatHotendTemp);
setTargetHotend2(plaPreheatHotendTemp);
setTargetBed(plaPreheatHPBTemp);
fanSpeed = plaPreheatFanSpeed;
Next, edit the code for the COOLDOWN menu item to call the new function as follows (disable the original line with //, and add one new line of code in its place):
Code:
static void lcd_prepare_menu()
START_MENU();
MENU_ITEM(back, MSG_MAIN, lcd_main_menu);
#ifdef SDSUPPORT
//MENU_ITEM(function, MSG_AUTOSTART, lcd_autostart_sd);
#endif
MENU_ITEM(gcode, MSG_DISABLE_STEPPERS, PSTR("M84"));
MENU_ITEM(gcode, MSG_AUTO_HOME, PSTR("G28"));
//MENU_ITEM(gcode, MSG_SET_ORIGIN, PSTR("G92 X0 Y0 Z0"));
MENU_ITEM(function, MSG_PREHEAT_PLA, lcd_preheat_pla);
MENU_ITEM(function, MSG_PREHEAT_ABS, lcd_preheat_abs);
MENU_ITEM(function, MSG_COOLDOWN, lcd_cooldown); // added 11/14/14: cooldown menu selection not working
//MENU_ITEM(gcode, MSG_COOLDOWN, PSTR("M104 S0\nM140 S0")); // disable since not working correctly, M140 is ignored
MENU_ITEM(submenu, MSG_MOVE_AXIS, lcd_move_menu);
END_MENU();
float move_menu_scale;
static void lcd_move_menu_axis();
Hope this helps someone besides me.
Jim
