BIG printer recommendations (ie 1 metre plus printing)
Hi all,
I'm new to this field.
I currently use injection molding for designs but i'd like to move into the printing world in order to provide more options without costly molds for each change in design.
I've been looking at the cheetah system, which is ideally sized at 2x1x1 metre print capability. I have concerns that the resolution is lower than i had wanted though.
I also looked at the 3DP workbench but that is less than half the size and twice the price.
So, what other options are out there for me?
Ideally, i would like to keep costs under $15,000 and i really like the concept of being able to use granules rather than filament.
If someone could point me in the right direction i would appreciate it.
Founder & CEO - Divide By Zero Technologies Pvt. Ltd.
Big printer recommendations (i.e. 1m cube) - SLA 3D printers print resin outputs which are photosensitive. You cannot use this printed outputs in broad daylight as it reacts with ultraviolet rays. I would suggest you to go for FDM or SLS printer as you get more practical and usable outputs. SLS printers are very expensive also the running cost is too high. If you are looking for big build capacity and economic printers go for FFF technology. Check out Big rep One V3 (Build volume-1000x1000x1000mm), gigabotXL (build volume- 590x760x600mm) or our 3D printer AION 500 (build volume-500x500x500mm).
