Punchtec Ord Bot - Clogging help
I have the Punchtec Ord Bot and i am trying to get PLA to work with it. ABS works fine but at higher temps.
Problem
So far with PLA it keeps getting clogged. after adjusting temps all the way to 240c and down to 190c at 50mm/s and it clogging randomly at beginning of print and sometimes not till way later in print. Every time i took the PLA out of the extruder i saw a bulging at the end. It seems that the PLA is clogging before it reaches the extruder. ive tried to adjust the extruder up and down from the feeding gear but it doesn't seem to matter. i have also tried 2 different PLA brands from merit line and Zeni Kinetic.
Any help would be appreciated please!?!
