Is there a way to turn off the light? LOL
Thanks in advance!
Thanks in advance!
Probably can unplug it. I think you can disable in the front panel options also.
insert a line in the g code file containing this M146 r0 g0 b0 That will turn the lights off.
Thanks Todd!
yep lights are in the front panel settings. On/off colour settings etc
I don't have them on the flashforge - but love them on the Klic-n-print.
Why would you want to switch them off ?
For over night printing of long jobs. I have the printer in my bedroom/ home office. That is the main reason. I have a room divider too, but it doesn't really cut down the glow from them. Thank you - like how you can change their colors too! :)
Ah... That makes sense. I run mine overnight all the time but I could not take the noise when I was trying to sleep in the same room.
The M146 command addresses the lights. The RGB values are adjusted from 0 to 255. For example M146 R255 B0 G0 would be a red light and M146 R0 B255 G0 would be blue. If you wanted purple it would be a mix of red and blue such as M146 R225 B225 G0.
Depending on what slicer you are using you can put the color change sequences at certain intervals such as pre-heat, print and post print.
I also found out the Flash Forge also has a control panel to let me turn off the lights from it, which is pretty handy. Just change the color to black and they turn off. :)
If you're into editing a long G-code file, you probably could insert the G146 command randomly throughout the file to produce many effects. Maybe a different color depending on the direction of the axis movements? (aka Disco 3D printing....)
Also, printing in the same room you sleep? Talk about "white noise" :)
It's possible with enough gcode editing. I would be easier to just wire them to a controller like this one.
http://www.dx.com/en/p/rgb-led-light...B#.VWTj8kaX21k
That would give you full control of the lights, patterns, color and strobing effects, etc
True, that could make thing's much easier :P
But I have been looking into the "Layer change G-code" editor in Simplify3D. I'm thinking there might be a way to set it up inside that. Set it to change a color at every layer change. Any idea's possibly? If I come up with something, I will come post it also.
