yep barnacules pretty much tried eberything and came down on sanding and wire wool.
However they don't easily remove print lines from recessed areas.
So I'm going to try the felt buffing wheel on my rotary tool as the first stage rather than the last.
Here's the latest pic:
Attachment 3641
The contrast between the raw print ganesh and the polished owls is amazing.
Basically without polishing prints look and feel like they're made from a rough stoneware ceramic.
Which actually fits the ganesh model probably better than polishing as it's taken from a very old statue.
So you actually get two very different finishes from the one filament.
I printed genesh hollow, so I'm going to stuff him with clay for weight and try the buffing wheel as a first stage treatment.
Ah - that's right. I weighed ganesh.
Bronzefill is 2.74 times denser than pla.
So to work out how much you're going to use for a particular print just multiply the grams the slicer it gives you by 2.74.
Or use that to add filament density to the slicer's settings.
Bear in mind a roll of bronzefill weighs 750gms. Sounds good - till you work out the length.
You only get the same length of filament as you'd get with 273 grams of pla.
ie: just over a quarter roll.
Use sparingly and make hollow figures wherever possible.
