Tips on basic settings?
You might swap the two extruder's heater and temperature sensor plug connections at the motherboard and see if the problem followed those. If the problem follows the swapped components, then the issue is most likely associated with those swapped components. As physical temperature involves significant thermal inertia, the issue is most probably with the temperature sensor. Bad connections / a failed temperature sensor are probable. Replacement parts are available from QiDi and there are videos on you tube (search for "qidi tech") showing how to perform the replacement. If your QiDi is still under waranty, contact QiDi for the parts. Sometimes they will ship via DHL which will cut several weeks off the delivery.
With the PeTG it was a bit tricky.
Bed 90 (PrinteBite) Bed 100 (blue sticker) nozzle 230, I've also slowed down to 24 on the print speed. No fan with panels on.
PLA dual printing bed temp 80 to 90 depending on the form, large areas needed hotter. Nozzle I kept at 210 to help blend the two filaments. Speed was 32 can go faster but for the really fine detail I kept it slow.
I made this fan duct in ABS though for printing PLA/PHA, first two layers no fan then 90%the rest of the time. Front door open but top on for the PLA/PHA but normal PLA for open, top off and side panel open.
http://www.thingiverse.com/make:256240
I hope it helps.
Old post, but I just added a glass plate, want to print a Z-axis spacer or whatever you want to call it, but how do you adjust the printer so that it allows for the extra space-does this piece do that on it's own or do I have to adjust Makerware (doesn't seem to allow for this) or whatever program you are using.
sorry, can't really throw the terminology around ;)
It will do it on it's own. Try to picture this, glass is .25" thick so that makes it that much closer to the nozzle, so you add a spacer for the Z axis limit switch that is .25" thick also and that makes the bed stop .25" further away from the nozzle.
One important thing is that when you put the spacer in is to adjust the bed way down with the leveling screws to make sure the glass clears then once you are sure then run your leveling as normal!!!
Thanks so much. I have the plate cranked down really far, hopefully the spacer will make this work!
Welcome mmccable, let us know how that turns out with the glass bed. :)
My printer is still going strong and has reached 3000 hours! What are the other QIDI's at right now?
Also wondering if anyone has any links to neat stuff that can be printed for a 3d logo to be placed on the front of the printer. I believe I saw something batman related before (wayne industries?).
