Originally Posted by
printbus
One observation on your settngs - you mention lowering Amax X and Amax Y to 500 mm/sec per second. I assume you are referring to what were the MakerFarm default values of 1000 either on the LCD or in DEFAULT_MAX_ACCELERATION? Note that there is another acceleration term Accel on the LCD and DEFAULT_ACCELERATION in configuration.h, which has a MakerFarm default of 500. As I understand it, the acceleration one gets is actually the lowest of either the axis specific acceleration or the global acceleration setting. With Accel set to 500, changing Amax X and Amax Y from 1000 to 500 actually had no effect since Marlin was already using that as the upper limit.
