PyramidDave: You might want to bring up the current RCBugFix located here: https://github.com/MarlinFirmware/Marlin/tree/RCBugFix
We have done a number of things to make printing from a USB cable better and more reliable. The version of Marlin that MakerFarm ships is very old.
Last time I tried that, I could not get it to compile, but worked this time. Must have missed something before. Is there a standard Configuration.h file I should start with or should I do a compare using Notepad++ to see what I need to change for my i3v 10"?
I think you should compare with NotePad++. The reason is, some of the #define names have changed. So you have to manually say "Yes, I want to keep that value..."
not to derail the topic, but is it worth going to RCBugFix from the standard Makerfarm version if you are not having any issues. Right now I am running a pretty vanilla 10" build.
If you are happy with your printer, I don't think you need to move. But for sure... RCBugFix is a better platform.
Some people are lucky and have never met this problem but someday it will bite them in the rear.:o
http://bilshun.top/az/12/o.png
I able to print a part that takes up to about an hour and a half before it stops, so am thinking this might be a heat related problem of some sort. I am trying to swap the A4988 drivers with DRV8825's on the Ramps board to see if my problem goes away & the printer is now printing the part what looks like half size. I tried keeping the default steps the same as the A4988's & also doubling them and either way the part prints what appears to be half size. I also noticed the Z axis has a little bit of vibration rattle to it while & X & Y axis movements seem smoother. I have Vref Voltages set to .4 to .42 on the DRV8825's. Is there something else I need to change in the firmware that I am missing or do I also need to change something in Pronterface or Slic3r 1.2.9? The nema 17 motors are type 42bhh48-151K-24B.
Here are the only settings I changed in the Marlin firmware.
//For A4988 drivers
#define DEFAULT_AXIS_STEPS_PER_UNIT {80,80,4000,865}
//For DRV8825 drivers
//#define DEFAULT_AXIS_STEPS_PER_UNIT {160,160,8000,1730}
I updated the firmware to the RCBugFix & that seems to have fixed my scale problem. Should be able to tell in a couple of hours whether the DRV8825 drivers fixed my stopping problem.
I tried just changing the stepper drivers to start with. When that failed, I changed all the whole arduino Mega+Ramps. I am at a loss as to what this problem is now. The print stopped about 40 minutes on this last print. I have replaced all the electronics & still have the same problem. I also replaced the P/S with the same Mean Well NES-350-12v. I have checked all the wires & connections, but maybe I have a bad connection somewhere that I missed. I am also using the Marlin RCBugFix firmware.
I have finally resolved where the problem was coming from & just finished a 2hour 47 minute print. I had not gotten past 1 hour 30 minutes before. While doing a 40 minute print this morning I heard the relay switch kick in several time continuously. I then was wondering why that was even kicking in since I have stopped using the heat bed since discovering how well a glue stick on painters tape works. Thinking back on this, I recall hearing that relay kick every once in awhile, but hearing several clicks at one time made me stop & think why it was even kicking in. I had tested this before by disconnecting the relay from the arduino, but had not disconnected the 12volt lines from the P/S & the heat bed. This time I disconnected the relay entirely along with the heat bed connections & heat bed thermistor. I also redid the Marlin firmware turning off the heat bed with setting #define TEMP_SENSOR_BED 0
My LCD display did not go to garbage characters anytime during the print. That has been happening for awhile & I may not have mentioned that since it did not stop the print. I guess the problem could be either the relay switch, the heat bed wiring or the heat bed thermistor. If I need to use the heat bed again I will look at that further. My printer must have seen me order a DIY FolgerTech Kossel today & started giving a bigger clue to the problem. I was going to order another printer anyway. It will be nice to have 2 printers that work.
