Has anyone looked into a modified bed platform? This one is quite flexible. It looks like it may not be that complicated.
A new issue! Now the printer won't heat to the set temp. If I set 195 it goes to 190, if I set 200 it does 195 etc. Never did this before. I did notice that the display is constantly saying "heating". Any thoughts?
Also starting to have issues with the outer shell adhesion.
This issue seem to be resolved. It does seem that the nozzle was tracing the outline and dragging so lightly that it didn't actually leave any marks.
Thanks guys for the good suggestions.
As far as the other issue seen of the outer shell layer not adhering I am fighting it now! It never ends.
Do you guys use the bed level wizard in S3D or just use the bed level from the printer control panel?
Wiring not included. Dave came up with a Z stage switch issue, but I sent him a couple designs to try.
https://lh3.googleusercontent.com/Sk...=w1184-h888-no
https://lh3.googleusercontent.com/Tj...M=w666-h888-no
https://lh3.googleusercontent.com/my...=w1184-h888-no
