This is a figure I made based on the style of Andreas' Agent 47 that he made based on the Hitman Absolution Collector's Edition Figurine. His Hitman can be found here:
http://www.thingiverse.com/thing:66072
I've cut my Lara into pieces to help reduce the amount of supports needed and to make the prints cleaner and easier to paint. The pieces peg together and will stay put, but she comes apart easily if not glued together.
I've included .x3g files that I used to print this (created for Replicator 2 with PLA filament). I've tried various ways to print the pieces and these files are the best combination that I've found. I've also included .objs if you want to set up the print files yourself or won't be printing in PLA. The body can print on its feet without supports and the left arm with the climbing hook seems to need a raft as well as supports enabled. The other parts only need supports. Here are estimate print times for the .x3g files I used.
Body - 96min
Head - 226min
PonyTail - 44min
Arm Left - 58min
Arm Right - 47min
Total - 471min (7.85 hours)
I hope you like this and thank you for looking.
