you might struggle with some flexible filaments on the ultimaker.
But both formfutura flexifill and fenner drives semi-flex are a bit stiffer so should work better in a 3mm bowden extruder.
Best material for limbs, casing etc would be pet.
Best for crash skids would be semi-flex.
Printed parts are every bit as strong as moulded parts. As long as they are designed and printed correctly :-)
Pet Tougher, easier to print with and a lot more bend/crash resistant than abs.
Thank you for the information. Is there one that you would recommend over the Ultimaker?
Jman - instead of waiting for Ulti 2 Ext., why not check out the Fusion3?
