#160 - Giant Crayfish (50mm)
http://www.thingiverse.com/thing:284090
http://thingiverse-production.s3.ama...w_featured.jpg
#161 - Chess Set - All in one ( ECO )
http://www.thingiverse.com/thing:284050
#162 - (almost) fully printed GoPro steady cam
http://www.thingiverse.com/thing:283925
Quote:
This steady cam only needs a few non-printed parts, the rest can be printed. Z rotation is enabled by a 608 ball bearing, while the other two axes are just running on M4 screws. A quick test beforehand showed this concept to be quite promising.
I'm still printing this, so I cannot say if it really works as planned. I finished the gimbal and this part works great so far. I will post some pictures after finishing the handle and the GoPro mount.After designing this, I found one here which is also very simple and cheap and additionally has a very nice design: http://www.thingiverse.com/thing:84142. Maybe I should have searched first ;-)
Anyway, this one is even cheaper. I paid 1 Euro for a 1m M8 rod and about 3 Euros for almost a kilogram of nuts and washers at our local hardware discounter. The most expensive part is the bearing - if you have to buy it. I took mine from an old pair of rollerblades. So, together with approx. 12 meters of PLA, total cost is much less than 10 Euros.
#163 - E3D Hotend v5 - SKP
http://www.thingiverse.com/thing:283890
#164 - Earring Completely 3-D Printed.
http://www.thingiverse.com/thing:283874
#165 - KK Mini Multicopter
http://www.thingiverse.com/thing:283863
#166 - Modified Adjustable Blower-Fan Mount 40mm
http://www.thingiverse.com/thing:283862
#167 - Minecraft Bookshelf
http://www.thingiverse.com/thing:283855
#168 - New Vertical Servo Gear
http://www.thingiverse.com/thing:283823
Quote:
I'm in the process of building the Solar Tracker designed by opensourceclassroom, but I did not like how the gears were supposed to attach the servos. So I designed a new vertical servo gear that has a hole going all the way through the gear as well as small pilot holes to mount the plastic arms from the servo directly to the gear.
#169 - 3D printer filament spool holder, fully-printable
http://www.thingiverse.com/thing:283656
