My CTC has the same rod bent. Not sure how much it is effecting the printer. But will probably try finding a replacement.
Nice. I need to upgrade the other board to match the firmware so I have a backup. When I first got it I thought I messed up something so I selected the 'Factory reset' option... BIG MISTAKE!!! It took it back to a makerbot with ONE extruder. It no longer sees the second one at all. I am not sure how to get this firmware off and onto the other, shouldn't be too hard...
Is this too loose?
http://youtu.be/iI9YGnjzRVY
From what I can see that belt looks ok.
Changing the number of extruders might setting might be in the menu under utilities.
I looked through every menu and unfortunately it didn't have any options. It also clearly said it was a makerbot creator, not a device with a dual extruder, this leads me to believe they copied the firmware from a single extruder device.
Is it possible to pull the firmware from this device??
Also I am almost certain I am going to buy S3D as I tried a dual print today and while it did complete and isn't AWFUL, it sure aint pretty either. I just hope it is a slicer issue (I used makerbot whatever to do it) and not the printer's abilities (I have seen images of beautilful stuff from them so I assume it isn't the printer lol.
See below.
Have you tried dual printing yet? I honestly will use the second extruder for support with PVA (Have some on the way to me now!!!) but would like to dabble in things with flexible filament here and there for joints and such, as well as nice two color prints.
Attachment 8664Attachment 8665Attachment 8666
I've not tried printing with the dual extruders yet. Usually just have different filament in them like PLA in one and PETG in the other.
Can you take a listen to this? Does yours sound any louder or quieter? The front to back sound seems nice and quiet and smooth, but now the left to right seems to have developed a loud noise... Maybe I am just being paranoid? Lol
http://youtu.be/eriNkt12vgc
Sounds normal to me
Under the advanced profile temp settings.
I set PLA to 195-200C with the bed at 60C.
ABS should be 230-240C with the bed around 100C.
PETG 235C and the bed 70C
If your in a colder area make sure the inside of your printer is at least 70F before you start printing.
