Originally Posted by
TK4426
Seeing shifting on the Y axis, and the weird thing is, it is hit and miss. I can run the same print twice and not see it on the first print but then appears on the second.
Pulled the sides off and checked the teeth on the belt and on the pulleys, all seem to be good. I also made sure the grub screws were in place and none were missing.
Tightened the Y motor, even though the tension on the belt seemed good. While I had the machine apart, I used your guide to oil the bearings (TY for the guide BTW).
Running another print now to see if it made any difference.
