Simplify3D also has a troubleshooting guide
https://www.simplify3d.com/support/p...oubleshooting/
Anyone have a glass plate setup on their QIDI Tech that I can see pictures of? Also how did you fasten it to the heated build plate? I ordered this already. http://www.ebay.com/itm/331831548659 which is 6 x 9 150mm x 230mm Borosilicate Glass Plate Bed Flashforege Replicator 3x Pack.
You don't fasten a glass plate anymore you use those pads to transfer the heat up and having at least 4 makes it where the glass doesn't move and if you ever need to you can simply lift the glass up off of them (some might come up but no big deal you just leave it or peel it off and place it back on the metal then place the glass back on).
I'm glad it was helpful and after my ~20 hour print completed today I started a 4 hour run and was happy to hear no noise. I do expect to have to re-oil in the future, but I will keep everyone updated on how long that takes. For right now I print only in ABS so far and have not ventured into the lower heat printing. I would suspect printing primarily PLA would put lower heat stress on the bearings.
