this stuff: https://www.amazon.co.uk/Supadec-dou...ded+vinyl+tape
It's what I've got my original sheet of printbite attached to my aluminium plate with on the flashforge.
double sided carpet tape should be the same stuff :-)
Hello again guys, today the thermal pad arrived, and for now seems to be working flawlessly with the glass, feels like it's glued and temps are just a bit lower, but i'll just set a higher print bed temperature in order to fill the gap, there's still something not that good with the default slicer, need to be working on how to use other softwares which will hopefully be better than that.
I've lost track - what slicer are you using ?
what's the printer :-)
Tried hairspray, with PLA works flawlessly, i tried printing 3 parts of the same keychain in ABS, set the extruder at 230, the bed at 120, sprayed abundant hairspray on it, it stuck initially, but after a while 2 of the 3 pieces started moving and the print fcked up, not that the hairspray i used it like from 10 years ago, and it says light, not super strong or anything, and the bed temperature it's not exactly 120, because the thermal pad absorbs a bit of the heat, so the print bed would be around 105 or so which should be more than enough for ABS to stick :/
