1 Attachment(s)
Can you diagnose this print?
Hello,
I have a type A Machines Series 1. I use KISSlicer. I tried pretty much every setting in KISSlicer but I can't seem to fight these issues.
The supports dont fully extrude, neither do small features. I get the extruder thinking its depositing material when it isnt. I changed my suck and prime settings to try and fight this, but if my prime = suck, then it will begin stringing badly as you can see in the picture.
To try and fight the stringing, I turn on wipe and use 4mm for that value. I also tried lowering the temperature to 175 from 185. It still drops out of the nozzle when moving from point to point. The temperature decrease does help, but does not prevent it alltogether.
In the picture I am trying to print out a small doll house for my daughter, to the right you can see little supports so the square windows can be supported when time comes to extrude the roof of the window. I tried almost everything, I am starting to think maybe it's the nozzle. The stringing wont go away, and the small features as you can see in the bottom of the picture, such as small supports, are not fully extruded.
http://3dprintboard.com/attachment.p...tid=4451&stc=1
Any input is greatly appreciated. I can show you guys more pictures if you need them for diagnosis.
Thank you,
- D
