MKS Sbase 1.3. Endstops "allways on"
Tevo Black Widow keeps eating 8bit boards. Upgrading to 32 for more speeeeed.
Everything went fine UNTIL i got to the endstops. They remain in "triggered" -state. Pins are correct, triple-checked. Tried both "^" and "!" in the config, no change. These are metal-detector sensors. They have a small LED in em that says they are triggered. Its on now allways. Wiring double checked, tested different setups, no change.
Config-file seems fine on that behalf.
Firmware is still a bit of mystery tho. Sbase is a Smoothieboard ripoff, story goes the firmware might not be directly compatible even tho it "runs" and the printer does move, heat, etc. Can this be a firmware issue? I'm not certain if this firmware is made directly for Sbase in mind or smoothieboard.
If anyone has a Sbase, metal sensors(3pin) and machine like Tevo BW then PLEASE, let me borrow your Firmware and config-file. I should be able to modify it to my needs.
If you need more details, please ask. I'm still new at this.
EDIT: Type of endstop
https://ae01.alicdn.com/kf/HTB1tebZK...3D-Printer.jpg
EDIT2: Something i forgot to specify. I'm migrating from MKS gen1.4 8bit to the MKS 1.3 32bit if it helps anyone.
