1 Attachment(s)
Beer opener
Hi!
I designed a beer opener. It is suppose to be printed in plastic, so to make it work, I made a place for 1 euro cent (for the metal part, that will open the bottle). I would like to ask if in your opinion should I print a hole like this with or without support? I cannot wait to print it and test it! :D
Attachment 7064
Thanks for any advice!
Why don't you start the print,reach end of the slot, pause the print, put the coin in the slot and finish the print ? That way you've all the support you want and it's gonna stay in place.
Hmmm... interesting idea, I didn't think about it! The problem is, that when I was pausing some print, there always a visible seam was created. For me more important is that the model will look nice from the outside and inside the hole eventually I may accept some "dirt" and try to remove it later... maybe I will try to put the coin inside without stopping the printer, but I don't know if I will succeed in this. Well and also it would be problematic to print then more than one model in time. I think for start, I will try to print it without support and see the effect. If it will be not satisfying I will try to use your idea! Thanks! :)
shouldn't need support. that's a pretty small gap to bridge.
So I decided to try it now without support. In three hours I will put here some pictures of printed models. :)
three hours !
that shouldn't take more than 30 minutes to print.
what are you printing it on ?
But I have to wait untli other print will be finished :D I will print it od DeGreen.
1 Attachment(s)
So this is picture of my print:
Attachment 7070
Inside the hole I had to clean a little with a knife, but now it's ok and the coin is staying on place. Thank you for your help! :)
Thanks! And the most important part- it works! :)
