1 Attachment(s)
Idler wheel stops spinning
I have a FFCP, had it about 2 weeks.
have about 20 or so hours on it.
I opened one of the spools that came with it the other day, (grey ABS)
and as i loaded the filament i noticed something odd. after a few seconds i would stop extruding.
after taking things apart and cleaning them, putting it back together and getting the same results, i ended up taking off the heat sink and watched as it extruded.
what i found was the idler wheel on the right (see attached pic)
will stop spinning. the stepper gear to the left it will keep spinning and subsequently chew up the filament.
I took things apart again, took the idler wheel out, put a dab of oil in it and put it back in.
same result.
i tried to tighten all the screws, loosen.. etc. same result.
I pushed up on the thump lever, there for putting more pressure on the wheel, and this made it extrude.
What i don't get is it was working fine, the spring still has plenty of spring.
I tried putting in black PLA and this did work okay, but as i watched it, i could see that wheel would occasionally pause, but then move again
i also noticed that whenever that happened the filament would move slightly.
I can freely spin this idler wheel with my finger, so it's not bound up in any way.
I measured the filament and it's 1.75mm
so i'm at a loss as to what is causing this and what i should do to fix it.
anyone have any thoughts?Attachment 6839
