3 Attachment(s)
Rosi LCD Controller for Rambo/Ramps with Marlin/Repetier; uses Viki LCD Config!
I know there are lot of LCD controllers for 3d printers out there. One of the nicer units was the VIKI LCD, but due to numerous problems with the uSD slots and other small issues (like being out of stock); I decided to make a similar BUT different controller that can fit where my Viki use to fit.
I have created the ROSi LCD (robotic operating systems interface). It works just like the Viki LCD in software in any supported software branch. Features the same control and LCD unit BUT with a full size TOP load SD slot.
A few other changes are how the SD LED is driven (it was direct before, now is runs off a transistor), header for the reset/pause (so you have have a "panic switch") and no problems with the memory card circuit coming loose.
I currently use a RAMBO 1.2/1.3 in my printer but it will work the same as the Viki in ANY documented 3d printer.
Attachment 6444Attachment 6445Attachment 6446
If anyone is interested in purchasing a unit, they are available on Amazon at http://www.amazon.com/dp/B010PVL80E
Any questions, please post them here or send me a PM.
Datasheet
