Do any of you use a part cooling fan with ABS? Is it possible to use that instead of slowing down when you have layers that take a short amount of time to prevent the goopy mess that happens when you go too fast?
Edit: ... I misunderstood... I print my abs with a cooling fan but i also print inside an eclosure so its warm air with a heated bed of 120 and a extruder temp of 250.
The fan hasnt caused warping yet and it helps especially on small layers with cooling sufficiently.
I printed aria the dragon with abs without issue using that setup.
