Monirad Robotics has just unveiled a new 3D printer which is robust enough to be considered 'Industrial grade' while price near the cheaper end of the consumer segment of the market. The printer which feature an all-metal chassis and extruder as well as an aluminum print bed and temperature controlled build chamber features the following specs:
- Printer Size: 23" x 18" x 21"r5
- Build Envelope: 12" x 10" x 10" (L x W x H)
- Layer Resolution: 80 Microns
- Print Speed: up to 180mm/s
- Printer Weight: 40lb
- Filament Size and Compatibility: PLA, ABS, Nylon, Polycabonate (Plexiglass ),HDPE at 1.75mm
More details on this new printer can be found here: http://3dprint.com/45780/rhino-3d-printer/
Below is a picture of the Rhino 3D Printer:
http://3dprint.com/wp-content/uploads/2015/02/r1.png
