Exact Maximum Build Dimensions
225 x 145 x 150 mm - that's X Y and Z right?
I printed multiple copies of the same small part successfully but the raft actually was built bigger than the build plate in the Y direction! I thought that was surprising. I stayed within the confines of the stock volume for the parts, but the raft gcode added its standard extra width?
I assume the dims are the same for the creator and the creator x?
Just wondering if anyone was able to print anything beyond these dimensions, really. Obviously your part needs to start solely on the build plate, but potentially could have the ability to sweep beyond the build plate dimensions as the part gets taller, given what I've seen.
