Hiding finished result
Using Creality CR6-SE with Creality Slicer 4.8
When the print job finishes the build plate goes all the way back instead of to the front. I've examined the resulting G-code and the offending line is
Code:
G1 X0 Y0 ;Present print
I can manually replace that line with
Code:
G1 X0 Y260 ;Present print
and load it into the Creality Slicer. However, doing so will not show the estimated print time. To see that I need to slice the .stl file.
How can I end a print job with the build plate going to the front instead of to the back?
some where in the slicer is a scripts section that adds the G1 X0 Y0 in the "End Script" find that and change it to what you want. I don't use that slicer but they are all the sameish
Thanks for your reply.
Yes, I finally found where to change the end script part. It's all working now!
