The Solidoodle 4 is Announced and Introduced
Just saw this this morning! It was announced on Engadget
http://hss-prod.hss.aol.com/hss/stor...1-24-31600.jpg
Quote:
The enclosure features two access point, a front door that shuts magnetically and a panel at top, both of which offer pretty good views of the heated print bed. The shell also means that the electronics are more protected on past units. The build area is 8 x 8 x 8 inches, compared to the Replicator 2's 11 x 6 x 6. There are some thoughtful tweaks throughout, as well, like the spool placement, which is now perpendicular to the printer, to prevent tangles and the vertical access adjustments, which no longer require a screwdriver. Cervantes managed to get the printer running without any adjustments to the platform, straight out of the box, which is impressive - though he did have to fiddle with the one of the fans, which had been knocked about in transit and was making a fair amount of noise.
So, plug-and-play, check. We won't say it's perfectly user-friend yet, though. While Solidoodle has done some work on the software front, we suspect there will still be a bit of a learning curve on that front for users who haven't spent much time with a 3D printer. Still, if you've got the money to spend and are looking for a way into the world of 3D printing, the Solidoodle 4 looks like it may be a solid choice. The printer is available for order today through the company's site. They'll be hitting Micro Center locations "in time for Christmas."
