Volumetric Extrusion settings
It's unclear to me after many Google searches exactly how to start with the built in volumetric extrusion of Marlin. I'm using Slic3r 1.2.9 and Marlin bugfix 1.1.x. Triffid Hunter's calibration guide seems to have written a blurb about using VE but it appears it was before Slic3r had support for it. If I understand correctly, by checking the box in Slic3r under
Code:
Printer Settings->General->Volumetric E
it means the g-code will be generated using extrusion values in mm3 rather than linear mm. In Marlin, the part that is unclear is what to send as the filament diameter to the M200 command. Do I use for 1.74mm filament, or do I use the generic (sqrt(1 / pi) * 2 = 1.128) as referred to in the RepRap G-Code documentation?
