Originally Posted by
LambdaFF
Well, here is a proposition, just to get you started, you can improve on it later.
Moving speed : 60mm/s
Vertical move speed : 30mm/s
Printing speed 40mm/s
perimeter printing speed : 75% of printing speed
1st layer printing speed : 50% of printing speed
number of shells : 2
number of top layers : 3
number of bottom layers : 2
overlap on perimeter : 20%
layer thickness : 0.2mm
retraction : 0.4mm (if you have an all metal hot end) 4mm (if you have a standard hot end)
Infill : 20%
infill pattern : 45° and -45° grid pattern
support trigger angle : 50°
support infill : 30%
support contact infill : 70%
support distance to part : 0,5mm
max un-supported area : 3mm²
printing temperature : 215°C for 1st layer ; 210°C for following layers
printing must wait for stabilized temperature before start
bed temperature : 60°C
fan speed: 0 for 1st layer ; 50% for layer 2 to 4 ; 100% for layers 5 and above
Min layer time : 10 seconds. allow under speed to 30%
once you get that working, we can work on a finish code that stops the heating and moves the head away from your part
Hope you have fun
