Qlone - an actual functional photogrammatical scanner - sort of :-)
youtube went and got me again.
This time with a phone/tablet based app called Qlone
It runs on android and apple - but, as I found out, much better on apple.
I have an ipad pro my mate gave me when he upgraded (more money than sense).
And a fairly decent android phone with 6gb ram and a good 8core processor.
qlone works by you printing a sheet with a series of black and white squares.
You put your iten on the mat and a dome 'appears' - sometimes.
I would recommend a turntable as well unless you can physically walk around and around and around your item, slowly while hunched in a series of increasingly uncomfortable poses.
To scan your item you click record and gradually turn the item until all of the dome disappears.
It's not as straightforward as that. the dome comes and goes, seemingly at random. And to get the final top of the dome is a true nightmare.
However, it does work.
I reckon on a good day you might get a decent scan in 20 minutes.
An a wednesday morning in september- call it 3 hours before I gave up on the phone and decided to try it on the ipad.
To date I have successfully scanned one item to a fairly impressive degree.
It's cost me £38 - because I had to buy it on google and apple - none of this: 'have a moveable licence' for these guys :-(
Now i bought one of those cheapo scanners a few years back and never even got a bad scan from it. that was £120
I have also tried various phtogrammatical programs in the past with exactly zero success from any of them.
Mainly because getting every single one of over a hundred photos with the exact same exposure while having to walk round the object (none of them allow the object to rotate and you to stay still) is nigh on impossible.
The fact that with qlone you can rotate the object, NOT the camera - makes it the most user friednly photo scanner I've yet come across.
There are a number of caveats:
1) the printed mat needs to be ABSOLUTELY FLAT. tape the bugger down. if not totally flat you will NOT be able to complete a scan. It's the single most crucial thing you can do.
I'm also contemplating glueing a large mat to a removeable top permanently.
2) different sized objects scan with different sized mats.
So print out a bunch in different sizes.
3) do not expect the distance and angle of the camera while scanning to be either consistent or logical.
You'd think a tripod would help - nope, so far i have only managed by holding the camera.
4) getting the stl from your android or apple device to a windows computer - use google drive. Runs on all three platforms and has 15gb for free.
Now that said - is it worth the money.
Of course it's worth the money !
I don't have £4'000 to spend on scan-in-a-box - the next best option.
1) I have succesfully scanned a fairly tricky object - an historical slingstone from guam made from coral.
2) exported direct to an stl from qlone and printed it. No messing about with meshes or worryi ng about whetjer it's a viable model - it just worked.
3) there are various options for editing the scan. Including one that takes the colour information and creates 'bumps' (basically the ins and outs) on the model to match the scanned colours.
So as long as you are not expecting miracles and have some patience - okay a LOT of patience. No, way more patience than that - think waiting for the heatdeath of the universe patient.
Oh and if you are prone to getting frustrated - yeah, you could be in trouble with qlone :-)
And providing you have a decent android or apple device.
For around £17 you can actually create fairly complex 3d models of objects that you can export in various formats and that need no further editing to print.
It requires work, sometimes a LOTof work, BUT It does work !
And it doesn't cost £4000 !
I've no doubt that when i get things setup properly and get a decent turntable, things should improve.
But damn I have digitally photocopied and reproduced an actual physical object !
Something I've been trying to do for over 8 years !
https://www.youtube.com/watch?v=sloeH7VWWYk
Just printing the better scan I made today, I'll upload pics when done.
If using apple you can even test the scanning process. You wuill need to buy it to export the model, but you can try it as many times as you like :-)
