4 Attachment(s)
Suggestions for print quality
I am not sure where this would go because it is a general question for my setup. Please let me know if there is a more appropriate place for the post.
I recently built my first 3D printer and have been playing with settings and tools. Today I completed my first relatively good print, compared to all of my test prints up to this point. But I am wondering how typical this kind of print is for my setup and if there are suggestions for the best print for what I am doing.
My printer is the Alunar M505 Prusa i3 https://www.amazon.com/ALUNAR-Deskto.../dp/B018XJ3E02 and I am using Hatchbox 1.75mm PLA. I am also have tempered glass on the bed https://www.amazon.com/gp/product/B00QQ5Q3BI/. I was playing with Cura 2.1.2 for a bit but was reading that 15.0.4 might actually be better, plus that is the version that comes on the SD card with the printer. The print I just did was with Cura 15.0.4. I am also using Pronterface to communicate with the printer from my computer (Win7).
I downloaded these miniature models from Thingiverse and used the wizard.stl http://www.thingiverse.com/thing:945822
Here are images of my print.
Attachment 10176Attachment 10177Attachment 10178Attachment 10179
I know that with supports, there will be some cleanup. But I am not sure how much of what is seen here is common or not. I know there is a lot of trial and error to getting things right, but are there any glaring errors that I am making with my current configuration?
These are my current Cura settings are mostly suggestions I have found online and played with.
Code:
[profile]
layer_height = 0.1
wall_thickness = 0.8
retraction_enable = True
solid_layer_thickness = 0.8
fill_density = 25
nozzle_size = 0.4
print_speed = 40
print_temperature = 210
print_temperature2 = 0
print_temperature3 = 0
print_temperature4 = 0
print_temperature5 = 0
print_bed_temperature = 60
support = Touching buildplate
platform_adhesion = Brim
support_dual_extrusion = Both
wipe_tower = False
wipe_tower_volume = 15
ooze_shield = False
filament_diameter = 1.75
filament_diameter2 = 0
filament_diameter3 = 0
filament_diameter4 = 0
filament_diameter5 = 0
filament_flow = 107
retraction_speed = 25
retraction_amount = 0.8
retraction_dual_amount = 16.5
retraction_min_travel = 0.1
retraction_combing = Off
retraction_minimal_extrusion = 0.01
retraction_hop = 0
bottom_thickness = 0.3
layer0_width_factor = 100
object_sink = 0
overlap_dual = 0.15
travel_speed = 120
bottom_layer_speed = 15
infill_speed = 50
solidarea_speed = 15
inset0_speed = 40
insetx_speed = 60
cool_min_layer_time = 15
fan_enabled = True
skirt_line_count = 1
skirt_gap = 3.0
skirt_minimal_length = 150.0
fan_full_height = 0.3
fan_speed = 35
fan_speed_max = 75
cool_min_feedrate = 10
cool_head_lift = False
solid_top = True
solid_bottom = True
fill_overlap = 10
perimeter_before_infill = False
support_type = Lines
support_angle = 50
support_fill_rate = 15
support_xy_distance = 0.8
support_z_distance = 0.15
spiralize = False
simple_mode = False
brim_line_count = 10
raft_margin = 5.0
raft_line_spacing = 2.0
raft_base_thickness = 0.5
raft_base_linewidth = 1.0
raft_interface_thickness = 0.27
raft_interface_linewidth = 0.4
raft_airgap_all = 0.0
raft_airgap = 0.1
raft_surface_layers = 2
raft_surface_thickness = 0.25
raft_surface_linewidth = 0.6
fix_horrible_union_all_type_a = True
fix_horrible_union_all_type_b = False
fix_horrible_use_open_bits = False
fix_horrible_extensive_stitching = False
plugin_config = (lp1
object_center_x = -1
object_center_y = -1
Thanks
