Tinyboy 3D Printer for Kids and Students designed from Hong Kong
http://www.thingiverse.com/thing:969645
Video :
https://www.youtube.com/watch?v=RVLiUBf1iGY
https://www.youtube.com/watch?v=KViu0PyYcm8
https://www.youtube.com/watch?v=_rW9SUn5Eho
Original design by http://www.thingiverse.com/thing:701548
Remixed from http://www.thingiverse.com/thing:776896
and http://www.thingiverse.com/thing:880110
OLED by http://www.thingiverse.com/thing:816376
This module can be used on every arduino mega ramps 1.4.
with Marlin version.
Updated :
- Arduino Mega 2560 + RAMPS + 4 x A4988 (Cheaper costs)
- LM4UU Bearing (Smoother movement)
- 2GT 16 tooth Gear (Easy Setting from Marlin)
- GT2 Belt
- OLED Display /w Tinyboy Splash Logo (Display Info)
- TF Card Module (Offline Printing)
- 4mm Thickness Acrylic Case (Stable Support)
- 3 x 35 Stepper 0.9 degree per step (Stable Movement)
- Bed Leveling using sping
http://www.HKMakers.hk
TinyBoy Website:
http://www.tinyboy3dp.net/
FaceBook:
https://www.facebook.com/tinyboy3dp
Supporting Organisation:
Hong Kong Creative Open Technology Association (HKCOTA)
Opensource Hong Kong (OSHK)
Hong Kong Linux User Group (HKLUG)
Less is more
The maximum size of printed object is 8 x 8 x 8cm , which is relatively small than many other 3D printer. However, it is already large enough for making things like figure and toy.
The gain from the trade off is the cost down of material and maintenance. Take out components for making large printed object , the design become simple and lean. The core material is acrylic sheet and connected by metal screw. Therefore , the cost of material and building can be minimized.
Easy to build / Learning by making
The process of making has the opportunity to transform education by inviting students to be something other than consumers of education. They can be maker of anything , moving from being directed to self-directed through the process.
Tinyboy is designed for easy to build. The assemble from kit can be done by just using a screw driver. We wish student can make their own machine. Then they become a pioneer whose may make another one for other people. So that the use of 3D printer can be spread out to more student.
The case of TinyBoy uses acrylic plane as the main material. Individual parts can be made by using cutter laser. Therefore, the manufacturing process is easy once you have a laser cutter. In fact , the price of an A5 laser cutter can be as cheap as USD $400. That make the cost of small amount production be reasonably low.
Specification
Size: 15cm(W) x 15cm(D) x 22cm(H) (excl. filament holder)
Printed size : 8cm x 8cm x 8cm
1.75mm filament / 0.4mm hotend
Contributors
Parker Leung (Designer)
Wan Leung Wong
Haggen So
Henry Law
TC Liu
Ben Lau (Honourable)
