LK5 Pro - Help with hot end assembly
Had to clean up after some bad clogging and replace the Bowden Tube.
I did not pay attention to the how far the hot end tube was threaded into the heater block.
I noticed putting it back together that where the hot tube bottoms out stops the nozzle from threading all the way in or, with the nozzle threaded all the way in, the hot tube will not thread all the way.
So, which threads all the way? Or is there some middle ground. The manual is short on information on assembling the hot end and in what order are parts are placed.
My assumption would be that the nozzle needs to go as far as possible into the heater block. and then everything else stacks up from there.
Anyone really know?
Since I have cleaned all up, I cannot get the printer to run from more than 30 minutes and it clogs from heat creep. That is that the filament is clogging in the tube and not the nozzle.
