Anycubic Photon Mono X resin residue issue
Hi all, I am using the water washable Eelegoo grey resin on my Mono X, and despite playing around with the settings quite a bit, I am geting reasonable prints, but with quite a large over print for the first mm or so, then after that the outer edges are left with half cured resin as a sort of gellid residue. As a result I am having to mechanically scrape off the gelly stuff, which can be pretty tenacious during the clean up phase, followed by tedious manual removal of the over printed layers.It is set to 0.075 layer height, with only 3 bottom layers, with base layer height is 30 secs with 1.7 for the subsequent layers.Can anyone advise on this? I produce mainly mechanical parts printing direct to the buildplate so that I guarantee a flatt(ish) back face so reducing the over print would be very helpful, even if I have to scrape off the gooCheersLes
